MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
mvvs 58 and 35 spark plug equivelents
Old 12-23-2007, 02:15 AM
negy1
Default mvvs 58 and 35 spark plug equivelents
i was told the brisk u17 plug was the same as the ur17 plug but it wont run on the u17 also need to know the nkg or champion equevelints thanks
Old 12-23-2007, 02:43 AM
DarZeelon
DarZeelon's Avatar
Default RE: mvvs 58 and 35 spark plug equivelents
Negy,
The NGK BPMR6F, or BMR6F, Champion RDJ7J, or RDJ8J, should be suitable replacements to the Brisk UR17.
You might have to file off the external terminal, for the original plug boot to fit, depending on what plug your engine originally had.
Old 12-25-2007, 07:57 PM
negy1
thanks for that info not many stock brisk plugs in the middle of australia
Old 12-26-2007, 09:47 PM
fiery
Dar is correct:
I have used NGK BMR6F and Champion RDJ8J plugs on my MVVS .26 IFS with complete success.
In each case, I used a wheel on my dremel to remove the tip, but a small metal saw would suffice. Only took a moment to do.
