MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
MVVS 58 Carby orientation
Old 06-09-2008, 06:29 AM
Jason Arnold
Jason Arnold's Avatar
Default MVVS 58 Carby orientation
Hi All,
Is it acceptable to rotate the carby 180 degrees on an MVVS 58?
The instructions say 90 degrees is acceptable but I'd like to go 180 degrees.
The engine will be mounted inverted in a Yak 54.
Cheers
Jason.
Old 06-09-2008, 07:26 AM
janch
Default RE: MVVS 58 Carby orientation
Hi,
you can turn carb 180.
Jan
Old 06-09-2008, 07:27 AM
pe reivers
With inverted engine, you can rotate the carb 180° if you like. In fact, you can rotate it in any position, though some reported a bit more difficult starting due to fuel dripping out of the carb instead of into the engine where it was needed most.
Old 06-09-2008, 07:39 AM
Jason Arnold
Thanks Guys,
I was concerned about the angle of the carby allowing fuel to run into the fuse. Having the carby angled upwards should prevent this.
Cheers
Jason.
