MVVS Support Get support from 3 qualified MVVS Forum Hosts. Dar Zeelon, representative from Israel. David Moen, representative from Canada. Pe Reivers, representative from Netherlands.
MVVS 35 Performane
Old 09-26-2008, 12:48 PM
catman74
Default MVVS 35 Performane
Hi,
I own MVVS 35 gasse. I would like to use this engine on a GP Extra 300 78" Patty Wagstaff with tuned pipe.
The model will turn out hopefully not above 15.5 lbs.
I am not for 3D acrobatics, but i would like to have some vertical performance and and doing classic aerobatics.
Is this possible with this engine?
Which prop do you recommend (thought 21x8)?
Shall i upgrade to the new MVVS 40?
cat
Old 09-26-2008, 02:24 PM
pe reivers
Default RE: MVVS 35 Performane
The 35 will be perfect for aerobatics, if combined with the 3271 muffler.
Extensive 3D, the tuned pipe or MTW TD75 canister would be better.
The 35 has a reputation of zero mechanical failures. The 40 is lighter and stronger, but there are no data on mechanical endurance yet.
21x8 is a good prop, but 22x8 will also do, with 22x10 the upper, and 18x10 the lower limit.
Old 09-26-2008, 02:28 PM
catman74
Thank you Pe,
So i will use the engine with the tuned pipe for best performance
regards
cat
Old 09-26-2008, 02:37 PM
pe reivers
Unlimited verticals will be yours. [8D]
