RCU Forums
-   MVVS Support (https://www.rcuniverse.com/forum/mvvs-support-322/)
-   -   Prop for MVVS 40cc (https://www.rcuniverse.com/forum/mvvs-support-322/10738607-prop-mvvs-40cc.html)
styk 09-28-2011 10:02 AM
Prop for MVVS 40cc
Hi
can i ask your advice on what would be a good prop for a MVVS 40 flying a 9kg 80" span P51 Mustang. Its fitted with a wrapround inverted pitts muffler. I was thinking about a 20x10 what do you think??
Best Regards
Styk
pe reivers 09-28-2011 10:43 AM
RE: Prop for MVVS 40cc
I think that would be a good choice. The pitts may be restrictive, so don't expect rpm in excess of 7000. (Jtec pitts power is about the same as MVVS muffler #3271)
styk 09-29-2011 12:12 AM
Thanks very much for the advice Pe. Much appreciated
Best Regards
Styk
pe reivers 10-02-2011 01:40 AM
good luck with your 'Stang project.
