RCU Forums
-   MVVS Support (https://www.rcuniverse.com/forum/mvvs-support-322/)
-   -   MVVS 35cc ICU - L magnetic sensor wire damage? (https://www.rcuniverse.com/forum/mvvs-support-322/10956835-mvvs-35cc-icu-l-magnetic-sensor-wire-damage.html)
BobV1700 02-13-2012 08:12 AM
Ive managed to damage the magnet sensor lead on my MVVS 35cc ICU - L by allowing it come into contact with the hot exhaust (yep, stupid I know). It still works OK but will require repair sooner or later. The wire leads directly into the black box which does not appear to be simple to open, presumably I can repair the wire by cutting out the heat damaged section and rejoining ie soldering, heat shrink, and a little more care!.
Thanks in advance,
Bob V<br type="_moz" />
Meesh 02-13-2012 08:24 AM
RE: MVVS 35cc ICU - L magnetic sensor wire damage?
Yes, just cut out the damaged section and solder new wire in. This will give you a chance to extend the leads if necessary.
Bob
BobV1700 02-14-2012 06:20 AM
Meesh ........<div>
</div><div>Thanks for that, is the wire 3 core or two core? anything special required?</div><div>
</div><div>Bob</div>
Meesh 02-14-2012 06:43 AM
I'm not sure but any type wire of similar gage will work.
