MVVS 35cc: fitting MVVS tuned pipe and header
Can anyone help with the approximate fitting length of the MVVS35cc / tuned pipe and header. Even better, the best way to fit and determine correct position within the airframe ?
thanks Bob V<br type="_moz" /> |
RE: MVVS 35cc: fitting MVVS tuned pipe and header
The MVVS 3268 tuned pipe has the 9" long header 3269 paired to it. This is best for standard use.
Fitting in the fuselage IMHO does not belong to MVVS support, but is a question of general nature. However, having said that, the pipe runs straight under the engine Center line with the cylinder fitted in the 7:30 o'clock position. |
Thanks PE,<div>
</div><div>Do I need to cut/remove any of the header pipe to find the optimum 'tuning length' or is it manufactured at that 'specific' length?</div><div> </div><div>Bob V</div> |
It's tuned as-is.
Thanks Pe.............<div>
</div><div>Understood.</div><div> </div><div>Bob V</div> |
| All times are GMT -8. The time now is 04:51 AM. |
