2.15 dem
I need the everall dementions of the 2.15 gas with ign. To see if it will fit in a plane I am bulding. Would this motor fly a 17 lb warbird with a little power left over? Thanks
RE: 2.15 dem
Rich,
Height from crankshaft centerline/under mounting lugs to top of head - 4.65". Length from crankshaft tip to back-plate bolts - 7.17". Crankcase width - 2.36". Width at mounting lugs - 3.31". Mounting bolt pattern - 2.76" x 1.62". All are rounded to the nearest 0.01". I hope these help. |
| All times are GMT -8. The time now is 09:19 PM. |
