RCU Forums
-   MVVS Support (https://www.rcuniverse.com/forum/mvvs-support-322/)
-   -   krumsheid header for 1.6 gas (https://www.rcuniverse.com/forum/mvvs-support-322/3545117-krumsheid-header-1-6-gas.html)
ampa 11-12-2005 09:36 AM
I would like to use one of these wrap around header with the original pipe. does someone already made these experiment?
pe reivers 11-13-2005 04:51 AM
RE: krumsheid header for 1.6 gas
Here is an example of a canister fitted with the KS header system. For the 26cc you need 22mm elbows.
ampa 11-13-2005 05:15 AM
Thanks for the answer: I would like to use the header that in krumsheid site is called double bent and transform a side exaust in rear exaust, these header looks redy to use and seems made of a single piece of inox tube.
pe reivers 11-13-2005 07:09 AM
with the fixed header the pipe will run at exhaust port height, and you need a tunnel in the hull. total header length should not differ from the supplied MVVS. It may be slightly longer if you do not run the engine beyond 8000 rpm.
ampa 11-13-2005 04:07 PM
these fixed hader allows the pipe to stay exact behind the cilinder ?
