RCU Forums
-   MVVS Support (https://www.rcuniverse.com/forum/mvvs-support-322/)
-   -   MVVS 91 POWER... (https://www.rcuniverse.com/forum/mvvs-support-322/4544284-mvvs-91-power.html)
ernesto_calvo 07-25-2006 06:03 PM
MVVS 91 POWER...
Hello Friends! I have a MVVS in a Summit 3 for performing F3A pattern. Even this is a small plane, It needs more power. I am using an APC 13x8 with 0% nitro (...) and a standar 3255 muffler. The fact is that everybody in the flying field says that the engine "is not good". The truth is that I really love it and I don´t want to sell the engine. I will try everything to make it run ok. Thank you very much!!! (and sory for my english!)
Ernesto Calvo - Argentina.
ernesto_calvo 07-26-2006 08:10 AM
RE: MVVS 91 POWER...
How can I do to increase power? Do you think that this is a good engine for pattern?
pe reivers 07-26-2006 01:14 PM
When the .60 is good for a 14x7 prop, what do you think you need for the .90?
try a 15x8 to 16x6 prop and see what happens.
The 3255 is not the right muffler. You should use the 3250 or 3253 if you need power.
ernesto_calvo 07-27-2006 09:05 AM
Thank you Arcen!
I want to tell you that when i bought my engine, the dealer told me that the apropiated propellers for this engine was 13x7 to 13x9. That is why I´m using it. But when I started flying, I realized that this wasn´t the right choice.
I will try with a 15x8, with the 3253 muffler.
See you!
Ernesto.
