mvvs 58 question
when engine mounted upside down does the carb should angle up or down!
RE: mvvs 58 question
BoatRacer,
Just leave it as it is currently mounted to the engine. The Walbro works well at any attitude. |
I found the engine very easy to start when the carb angles downward, so no fuel can drip out when choking the engine.
With the choke on, I now bump the engine to and fro against compression untill I hear the wet hissing. Choke off, ignition on, and the engine starts first flip. |
| All times are GMT -8. The time now is 02:07 PM. |
