RCU Forums
-   MVVS Support (https://www.rcuniverse.com/forum/mvvs-support-322/)
-   -   Isolation mounts (https://www.rcuniverse.com/forum/mvvs-support-322/5723109-isolation-mounts.html)
BaldEagel 04-16-2007 06:15 AM
Isolation mounts
Pe
You may remember I bought the MVVS isolation mounts from you some time ago, well I have now unsed them in my 2M Extra and can report that far from the popular belief that iso mounts increase vibration these are so efffective a pal of mine who is also a petrol head could not belive the lack of vibration in this instalation, In a normal hard installation the tail or wings will vibrate up and down at tick over and only smooth out when you advance the throttal, in this case the plane is smooth all through the rev range and just sits still at tick over with no vibration noticable at all, obviously the work done installing the anti vibration mounts was very worth while, none of the screws used to mount the cannopy, cowl or anything else have moved thoughout any flight, My pal was so inpresed he did not stop going on about it all day, he is now a convert.
Mike
pe reivers 04-16-2007 08:06 AM
RE: Isolation mounts
One way to silence a pal I presume? Some people just need convincing.
Having my own iso mount system, I did not use the MVVS system. Thanks for the report.
Fly Low71 09-23-2025 12:31 AM
Hi
Originally Posted by BaldEagel (Post 5723109)
Pe
Mike
Hi rhere, di you have any pics of this mount ? Also these days hhe mvvs website does not offer anything for the glows wngunes.. has anyone made a diy mount ?
thanks
