Radial Mount Dimensions
Gentlemen,
I am considering the installation of a radial mount for my 35GT2/MVVS 2.15. Does anyone have the dimesions for the following? 1. Distance from firewall-side to engine side-base (projection) 2. Outside diameter of firewall base mount. I tried looking online and emailing Horizon Hobbies, but I haven't received an answer. Thanks in advance for your assistance. |
RE: Radial Mount Dimensions
Chock!,
I currently have none of these radial mounts in stock, but Pé Reivers does... Maybe he can take the needed dimensions and post them here for you. |
http://www.mvvs.nl/MVVS/images/3398R.JPG
I will make a drawing with the main dimensions: Main diameter = 95mm height = 19.5mm bolt pitch diameter pattern = 83mm (pre centered for 8 bolts) weight = 80 grams |
Gentlemen,
Thank you both, for your expertise and prompt reply! It looks like the radial mount will serve my application well. |
| All times are GMT -8. The time now is 05:42 AM. |
