RCU Forums
-   MVVS Support (https://www.rcuniverse.com/forum/mvvs-support-322/)
-   -   New 50cc Evolution (https://www.rcuniverse.com/forum/mvvs-support-322/7424467-new-50cc-evolution.html)
octanehuffer 04-26-2008 11:04 PM
New 50cc Evolution
I see that Horizon Hobby anticipates the new 50cc in July. Currently I am running a 45GX2 with great results, but always wanted 5 cc more power. For practical purposes lets say that my 45 has 1.85hp /lb. Factory specs. Does the 50 have the same or greater rating? I see that the engine is 9 oz heavier and it must make 6.2 hp to match the power to weight of the 45. Would it be worth a swap? What will it swing a 22x10 to? My 45 swings a 22x10 to 6900 rpm.
Adam
DarZeelon 04-27-2008 01:18 AM
RE: New 50cc Evolution
Adam,
MVVS does not have any 50 cc on their site...
Can you please post a photo of the engine anticipated by Horizon (I couldn't find it in their site either...), so it can be determined if this is an MVVS engine, or not?
If not, MVVS does not support it.
the Wasp 04-27-2008 02:53 AM
looks MVVS to me,,,
http://www.horizonhobby.com/Products...rodID=EVOE50GX
DarZeelon 04-27-2008 03:27 AM
Thanks for the heads-up, James.
It must be a stroked-down (probably a bit lighter) 58 cc engine (no mention of a magnesium crankcase, a la 45 cc engine, or a specific weight).
It does not appear in the MVVS line-up yet.
octanehuffer 04-27-2008 08:13 AM
The weight is 53 oz. Just engine. What are the two little nipples on the front bearing?
pe reivers 04-27-2008 02:21 PM
MVVS is still very hush-up about the engine.
It is a 43cc stroke crankcase with a blown-up cylinder.
The nipple up front is so the factory/user can apply extra lubrication for the front bearing and seals.
When in Nürnberg at the Toy fair, several engines were equipped with this feature, along with increased play between crankshaft and crankcase.
If you study their flyer leaflet closely, you can see it at http://www.mvvs.cz
the Wasp 04-27-2008 04:01 PM
geezz 53 o.z.,, that is what my MVVS 35 weighs :(
Jim
Greg Cothern 05-12-2008 02:19 AM
So in theory can those of us with the 43cc MVVS' simply replace piston, ring, and head to have a 50cc? I have one 43 that stripped the exhuast mouting tabs and the ignition went bad (I have a new style ignition which would require me to buy a new head anyway to work with the ignition) so if I have to outlay the $$$ would be nice to build it into a 50cc...
pe reivers 05-12-2008 03:23 PM
Since they advertise the 50cc version, contact Horizon, and they most certainly can tell you your options.
