RCU Forums
-   MVVS Support (https://www.rcuniverse.com/forum/mvvs-support-322/)
-   -   Evolution/MVVS 26gx (https://www.rcuniverse.com/forum/mvvs-support-322/8234793-evolution-mvvs-26gx.html)
ggroyal1 12-11-2008 09:10 AM
Evolution/MVVS 26gx
1 Attachment(s)
I receieved my new Evolution/MVVS 26gx engine today. It did not come with breakin oil(my45gx2 came with break-in oil), can I use Amsoil 100:1 golden sabre at the 30:1 mix for break-in. Mobil 1 quit making 2T racing synthic oil. Does the slanted spark plug add anything to the performance? The engine is going into the H9 Sundowner and I plan to use the tuned pipe that goes with this engine. Is this engine different on break-in because of the piston and cylinder material? In the past I used Penziol air cooled 2 cycle at a 32:1 mix for the first 2 to 3 gallons and then switched to Amsoil 100:1 mix. This engine looks well made and if it is as good as my 45gx2 it will be a great engine.
George G. Royal
DarZeelon 12-11-2008 09:57 AM
RE: Evolution/MVVS 26gx
George,
The header that is used with this engine is the [link=http://mvvs.cz/obrMVVS/prislusenstvi/3265.jpg]MVVS #3265[/link] and the muffled cone-and-disk tuned-pipe is the [link=http://mvvs.cz/obrMVVS/prislusenstvi/3266.jpg]MVVS #3266[/link].
Regarding the oil, MVVS do supply break-in oil with the larger gas engines (45 cc and up), but it is up to you with the smaller ones.
I would adhere to what head engineer Josef Å*vajda determined as the right mix and I would not use 100:1 oils at this percentage.
Use two-stroke oil at 30:1 for break-in and 40:1 afterward.
pe reivers 12-11-2008 02:33 PM
ORIGINAL: ggroyal1
George G. Royal
In the new design engine, you can use the pennzoil and stick with it at a ratio of 3% oil.
If you plan to use the 100:1 Amsoil, (not recommended) mix it at 2% (1:50) This oil has a mix range of 1% -2%. Any less than 2% oil, and these small engines will be starving for oil.
BTW,
Mobil 1 is still available. I have it in stock.
ggroyal1 12-12-2008 05:28 PM
Thanks Dar and Pe,
Is the break-in oil that comes with the larger Evolution/MVVS engines Mobil 1 Racing 2T? It looks the same to me. You guys are very helphful and provide a lot of good info. With the internet, it seems like I really know you, and I am really talking to you. Have you two ever met in person? Keep up the good work.
George G. Royal
pe reivers 12-13-2008 08:05 AM
Yes it is Mobil1-2T racing, and MVVS has ample supplies to serve their customers welll.
PS:
No, Dar and I never met in person whenever he decides to go to the Nürnberg toy fair we might.
stev_1 12-21-2008 09:31 AM
do not use the wrap around muffler they sell for it. If using a tri gear plane the chamber is to big and won't fit, also the exhaust pipes pointing dwn are not centered on the engine and one of them hit the gear. I wrote/called them about it when the engine first came out and they have not fixed it and they do not respond back. I ended up using a jtech muffler
