Go Back  RCU Forums > RC Airplanes > ARF or RTF > NitroModels Support
Reload this Page >
Zlin Z-50 recieved
NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Zlin Z-50 recieved
Old 01-18-2009, 01:40 PM
  #101
eagle09tbl
eagle09tbl's Avatar
Default RE: Zlin Z-50 recieved
Thanks for the reply.
Looking forward to getting this one in the air soon.
Old 02-24-2009, 04:07 AM
  #102
goph
flew my zlin a few times 1st time with the rates down low hd to turn them up as it flew like a trainer.
have had a problem with rudder giving a fluter.
been playing around with the pitts muffler , changing pipe out let diameters. to change back pressures.
lastflight had big problems with interfirance , found throtel push rod rubbing on muffler.suspect that has been my problem.
will try this weekend , weather souldbe good.
has every body has good reports.
Old 02-24-2009, 10:18 AM
  #103
eagle09tbl
eagle09tbl's Avatar
Zlin test flight a few days ago and here are the results.
Had to add 8 ounces of nose weight to get it to balance, was built exactly per instructions. Plane is a bit unstable on take off and landing. It seems to want to snap at lower speed which was expected. 1st landing was without problem, 2nd landing the main gear broke loose from the fuse. Not a hard landing at all and was on a grass runway. IMHO this isn't a high quality ARF kit and while the plane looks great, it was much more time consuming to assemble than most others. Many areas of the kit needed reinforcing for strength and that was done which contributed to the extra assembly time.
Overall in the air the plane flew fine. Rolls, loops etc were all good, just remember that takeoffs and landing can be a bit scary if you aren't properly prepared for it. For an experienced pilot really no problem to fly it, but someone who hasn't flown this style of plane likely would have some difficulty with it. I've never really enjoyed flying a plane that I can't be comfortable with, and this turned out to be one of those. I simply couldn't relax and enjoy the flight as I usually do, so just not a thrilling experience for me.
I will say that this was the first Nitro Model kit I have had any dealings with and unfortunately, I was not very impressed with the quality. I simply think there are kits available elsewhere that are a higher quality and better value.
Old 03-01-2009, 04:43 PM
  #104
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
As soon as the rain lets up I'm going to maiden my Z50. I used a EFlite Power 60, 6 cell lipos, 16x10 APC and a nicad for the servos. I came out right on the Cg of 80mm but I just changed to bigger wheels up front so hopefully a bit more nose heavy as I think the Cg is a bit to aft as it is. The throws listed are a joke! No way should you need that much Elevator unless you are doing full out 3D flying! Anybody find some nice throws and rates for this plane? Also I drill hole in the struts and run a rod across, that way they don't bow out and break. Also better ground handling. I was hoping this could do some 3D but not sure now that I read the posts!
Old 04-20-2009, 07:22 AM
  #105
hugh durden
My Feedback: (44)
I should fly mine Thursday with a 100 saito
anyone tried this?
Old 04-20-2009, 09:47 AM
  #106
mando
mando's Avatar
Welcome, I'd say WAY too much power for this CMP, and will also make it way too nose heavy........then again, it does need nose weight......
Old 04-20-2009, 10:05 AM
  #107
hugh durden
My Feedback: (44)
I got it from a man quiting the hobby, he had a saito 100 on it. I will find out soon enough, I guess.
thanks for your reply
hugh
Old 06-01-2009, 10:17 PM
  #108
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
Where can I get a wing?
Old 06-07-2009, 08:44 PM
  #109
STRAUBMAN
Finally got mine to the field today. I wasn't sure I'd even like this plane especially with some of it's reported bad characteristics. Ihave a Rossi 45 with a pitts hanging on it. Our field expert flew it and trimmed it up.He loved it and thought it flew awsome.Easy to take off and land,After 3 short test flights with some throw adjustments it was my turn. I refueled and startad the engine. It shut down several times going to high throttle. Thinking it was the glow,I changed it. Finally got it to stay running. Touched the needle valve and it died. Looks like I have a loose valve or something. Short story long, I never did get to fly it myself. Will update when I finally get it in the air.
Straubman
Old 10-13-2009, 03:12 AM
  #110
goph
how can i get a new wing here in australia
Old 10-13-2009, 08:03 PM
  #111
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
I tried and never could get a wing set. I was told they were out and would ship me one when they came in. That was about six months ago. Good Luck.
Old 01-17-2010, 11:51 PM
  #112
crfd
I know it's been awhile since this post was active but I'm wondering how you guys like your Zlin z-50 planes.
Would you still buy one. Or would you recomend somthing else like it?
CRFD
Old 01-18-2010, 12:03 AM
  #113
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
ORIGINAL: crfd
CRFD
Read the posts above and good luck!
Old 01-18-2010, 04:39 AM
  #114
goph
have you been able to get a new wing?
Old 01-18-2010, 10:32 AM
  #115
flyguy506
I miss my Zlin. I did not like the kit. See my post above. I did like the yellow and black because it was easy to see and I liked the looks. I got numerous compliments on how the aircraft looked in the air. I thought it was easy to fly and ground handling was great after I modified the landing gear. I crashed it after my berg 7 decided to go to sleep on me. It is different with the T-tail. I would recommend it for the sport flyer who likes to build and wants something different.
Old 01-18-2010, 09:08 PM
  #116
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
ORIGINAL: goph
Nope...gave the fuse and broken wing to a person who could use it.
Old 02-07-2010, 12:12 AM
  #117
BIGDADDY89
Old 02-07-2010, 03:40 AM
  #118
flyrcjets
My Feedback: (30)
flyrcjets's Avatar
ORIGINAL: BIGDADDY89
I'll second that!
Old 11-01-2010, 01:51 PM
  #119
2711
I had one and loves it. Battery in my TX went south and so did my Zlin. I have another on the way finally.
I will put together all of the things I learned on the first build (Crappy landing gear, poor hardware and needed gusseting)
to use this time. I like the way she looks in the air and what the heck, it's a cheap airframe. Cant Wait!!
Old 12-07-2011, 02:26 PM
  #120
Gmann6843
Anybody still following this build blog? I just bought a Zlin Z-50 from NitroPlanes looking forward to building and flying the aircraft
Old 12-11-2011, 08:43 PM
  #121
Gmann6843
<tt>Will a Aluminum Spinners:[/b]</tt> [/b]57mm/2.25in be the right size for this aircraft.
[/b]
Old 12-12-2011, 10:11 PM
  #122
Gmann6843
[/b]
<pre>So I got the Zlin-Z50 today and couldn’t wait
to see what she might look like. Had to trim
the canopy and it still needs more trimming
and the wing had some damage but nothing
that would stop me from putting her together..........
[/b]
</pre>
Old 12-17-2011, 12:06 AM
  #123
Gmann6843
Old 12-17-2011, 12:08 AM
  #124
Gmann6843
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
