bobcat 25 with .46ax what prop?
FL
like the title says i have a bobcat 25 with a .46ax i was wondering what would be the best prop?
i was thinking somewhere along the lines of a 10x7 or somthing in that area.
RE: bobcat 25 with .46ax what prop?
If it fits a 10x7 will give you fantastic thrust and decent airspeed with that motor.
Have you already installed it?
The weight of the engine shouldn't be an issue, but the size of the fuel tank ( adding more weight ) might.
I'm running mine electric @22volts 4000mAh in a 3S2P configuration, and the plane screams this way.
It is roughly equal to a .32 engine, but because IMHO it weights more with the dual packs I was looking to replace the motor with a glow .32 to save weight.
