manual for bobcat 50
I cant seem to find the manual for the Bobcat and I wanted to double check a few things befroe final assembly. Does anyone have a online manual or a scanned copy .
RE: manual for bobcat 50
Anyone needing a PDF copy of the manual can PM me their e-mail address.
It is 7.5 megs in size, so your ISP must permit through message attachments of this size.
CA
sure can I get your email?
John
Nitro Planes
John
Nitro Planes
ORIGINAL: dhooker
Please send the builders manual for the Bobcat 50 Pusher jet, I have the ARF without instructions.
Thank you,
Don Hooker
Thank you,
Don Hooker
FL
PA
Hello,
I just bought a Bobcat 51" wingspan, that the former owner had a thunder tiger 71 on it. So I am currently mounting an OS copy 65 on it. So what I need, is a manual to verify the CG? Would someone tell me where the manuals are posted or email it to me?
2nd question: I have what they tell me is a OS65 Russian copy: Mutunuc Millennium 65ABC.BB, is this any good? it is brand new, in the box, bought it from a SK fuels rep who never used it and was new in box with muffler and basic mfg sheet.
Prop? The guy who sold me the plane used the 71 thunder tiger with a 11x7P pusher prop, is this the best prop?
[email protected]
[email protected]
Please, can you send me the bobcat 50 instruction manual. Thank you .... [email protected] .
Re: CG
See: [link=http://www.rcuniverse.com/forum/m_6075924/anchors_6077471/mpage_1/key_/anchor/tm.htm#6077471]One of many Bobcat 50 threads - Click me![/link]
Note:
The plane MUST have a positive angle of attack! ( leading edge of wings higher than trailing edge ).
You must set the C.G. with the tank FULL or nearly so.
1/4" of reflex ( aka spoilerons ) are almost a must for landings.
Re: Thunder Tiger 71
I use an 11x8p Graupner prop with my GMS .76 and Tower Hobbies .75 engines. However both of these produce more power than the TT .71 engine so the 11x7P sounds like a good match with yours.
Dunno about the engine. You could try posing a question about it in the engines section.
Note:
Please, Somebody have a instructon manual for a bobcat 50 nitroplanes ? Just bought this plane and comes without the instruction manual. Will be very helpfull . email me if you have it in a pdf. Thank you....... [email protected]
CA
10.3" is the CG measurement for this plane, I know that some of the manuals from Nitroplanes actually had a wrong measurement in them and others were correct.
