NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
p40 60 Question
Old 12-14-2008 | 01:25 AM
Default p40 60 Question
Is the P-40E 60 - 63" Tiger Shark Nitro Gas Radio Remote Controlled RC Warbird Plane ARF in stock ?
I want to get one for a Christmas present but I dont want to order it just to find out to late it is on backorder.
Old 12-14-2008 | 08:02 PM
nitrostaff1's Avatar
Default RE: p40 60 Question
Yes it's instock and ready to ship. Please order here: http://www.nitroplanes.com/p6063tishnig.html
John
Nitro Planes
Old 01-12-2009 | 03:31 PM
how are u supose to put the servos into the fuse. it doesnt say in the instructions
Old 01-12-2009 | 04:10 PM
opjose's Avatar
ORIGINAL: charlesp
I don't have that particular plane so take this with a grain of salt...
Basically that is up to you....
If there is not an obvious location to insert the servos, you may have to fabricate your own servo tray out of ply stock, and affix that to the fuse sides.
If there are existing cutouts, make a small shim out of scrap ply. These need only be small squares and you do not have to do anything as elaborate as in P10 of the manual for the aileron servo... rather glue the small blocks to the underside of the tray to provide a location to drill into. Once dry drill starter holes for the screws and install much like the aileron servo.
You may want to seek the aid of someone used to putting together ARF's if this is a bit confusing.
Old 02-18-2009 | 11:08 PM
I just bought P40 60. there is no servo tray for elevator or rudder. Am I expected to fabricate my own? Does that still make the plane an ARF? The instructions point to an area where you might want to locate them. There are no control rods anywhere near long enough.
Are all models this skecthy or did I just pick a winner?
Old 02-19-2009 | 09:28 PM
what's your order number? perhaps you are missing piece of hardware.
John
Nitro Planes
ORIGINAL: gracer52
Old 02-19-2009 | 09:47 PM
do you keep a open plane box of each model to answer any questions. This might be helpful. I heard you were understaffed to provide this kind of support?Jose told another customer to fabricate his own servo tray. I just am worried about C.G. because the control rods seem short and Ive seen planes that you attach rods to wood dowels. maybe I'm missing those? The instructions are just unclear. Im fairly new to this kind of building but I would like to tackle these kind of problems as they arise.
Thanks again for your help.
Old 02-19-2009 | 09:49 PM
so what's your order number?
John
Nitro Planes
Old 02-19-2009 | 10:04 PM
524671
Old 02-19-2009 | 10:37 PM
I just read the instruction and it's alright. Yes you have to make your own servo tray to put in the servos on your own. The CG remains the same and I don't think it will change anything after you build the servo tray. Yes wood rods are A+.
John
Nitro Planes
Old 02-19-2009 | 10:47 PM
Thank you for the help! looking forward to buying more planes.just need$$$. Economy bad, prices good! your online support is very helpful. I will do more research next time.
Old 03-12-2009 | 02:53 PM
what is the cg point on the wing and the angle of the alireon and elevator because the manual does not say?
Old 03-14-2009 | 10:20 AM
You need to go to modelflight.com.au/manuals/pdf/hanger9/han2850-manual.pdf This is the same plane basically and the plans are
far better than the ones that came with your plane. good luck!!!
Old 03-14-2009 | 11:36 AM
I too am having a great deal of difficulty in putting this model together. I understand I need to make my own tray, my question is hooking up the wooden rods to the rudder, and elevator. Do I have to drill somewhere so that these two rods run from inside to outside of the fuse? This is my first ARF kit, so if your could explain it so an idiot can understand, that would be appreciated.
Old 03-14-2009 | 01:17 PM
Good Luck, it is challenging.The servos for the elevator and the rudder actually mount in the fuselage by the tail.The Ip address
for the hanger nine manual are in my last post. They are very helpful, step by step for the novice builder.
Old 03-14-2009 | 01:39 PM
LDM
My Feedback: (15)
Nitro staff can verify my comments , but the 60 size P40 (not the CMP versions ) but the one that has P51 style retracts , was originally designed by the company that marketed under the sportman avaition brand .
I have over 9 P40 so I sould know because I have these planes .
The original design was very easy to fly and can be flown eletric .
When in doubt on the CG , use 25% of the maximum wing cord measured near the fuse .
If you have never build an arf , get yourself a good book avaiable on any web or hobby shop on tricks and techniques .
It will give you tons of pointers on cutting cowls , pushrods exits ect .
Or look up the original VQ P40 build thread , ton of good points on arf assembly that yuo can use .
Old 03-15-2009 | 05:48 AM
Mr.Freeze's Avatar
Hey I'm new to the plane scene but have been an avid rc boater for some time, what is the deal with the out of stocks? It's like over half of the site is not available. I'm looking forward to picking up a new warhawk but they haven't been available for quite some time.
Old 03-15-2009 | 09:27 AM
I have a question about the .60 size P-40. On the one I bought from Nitro Planes the elevator comes in two pieces. I think this is a design flaw. The instructions show one piece. Has anyone else experienced this problem?
Old 03-15-2009 | 09:34 AM
there is a u shaped rod that goes from one to the other. drill a hole and cut a slot in the elevators.did you look at the h9 manual?
Old 03-16-2009 | 06:09 PM
page 9 is missing from the manual. i had to download it from nitroplanes.
