Go Back  RCU Forums > RC Airplanes > ARF or RTF > NitroModels Support
Reload this Page >
New! Hero Eagle 100 Fiberglass Electric Ducted Fan
NitroModels Support Click here to have all your questions answered directly from the NitroModels support team.
Old 01-04-2009, 10:13 PM
sdjb
Default New! Hero Eagle 100 Fiberglass Electric Ducted Fan
AnyOne Have any toughts on power system for this plane? Sure looks good and I WILL HAVE ONE {just dont tell my wife and were good}.
Thanks Steve
Old 01-05-2009, 01:40 PM
opjose
opjose's Avatar
Default RE: New! Hero Eagle 100 Fiberglass Electric Ducted Fan
At 14-15lbs AUW ( projected ) you'll need at least 1200 watts PER EDF(!) for good performance.
At the stated 101mm that's a good sized EDF too... A WeMoTec may be appropriate.
With a combo like that, it will be an interesting plane to see and fly.
Old 01-08-2009, 07:54 AM
steve2972
looks nice!,I`ll keep an eye on this thread[sm=thumbs_up.gif]
Old 01-19-2009, 09:52 AM
slevin1
My Feedback: (23)
Steve,
Try this for powering the plane. It got a good write-up in a recent issue of "Sport Flyer."
www.tamjets.com
http://www.tamjets.com/edfunits.php
Here is the complete plug & play set for the TJ100:
http://www.tamjets.com/original/prod...roducts_id=419
You can also see the fans performance on the Tam Jest website.
If the price is more than your wife.......wants to spend then try this:
http://www.hobbycity.com/hobbycity/s...idProduct=4241
Also try this:
http://www.rcuniverse.com/forum/m_79...tm.htm#7931784
Saul
Old 01-22-2009, 08:23 PM
mark_d
The only drop in fan is the himax: the hoaye needs some fitting for more information go here: http://www.rcgroups.com/forums/showt...0#post10524795
the fan is here:
http://www.maxxprod.com/mpi/mpi-267.html
It seems strange that nitro does not sell a fan to go wtih this.
Old 01-27-2009, 11:25 AM
TOPCELLULAR
I have one of this plane, but somebody can help me to choice the best battery pack and Speed Controller, the EDf's are 2 Himax EPF96BL.
Thank you!!
Old 01-27-2009, 07:44 PM
sdjb
slevin1
Thanks man but I put it on hold for awhile yet. Need to put a new roof on my house[] May next month I can start back on it.
I'll be sure and post as soon as I do.
Thanks again the fan looks good
Steve
Old 02-05-2009, 07:29 PM
Mr Ray
Finished mine today except for thr motors which are in transet. This is probably the worst arf I have put together. Poor fit, just about everything had to be worked to fit. Nice looking plane, hope it flyes as good.
Ray
Old 02-05-2009, 08:40 PM
b17flyer
My Feedback: (32)
watching this also for fans/motors
Old 02-05-2009, 10:19 PM
opjose
opjose's Avatar
ORIGINAL: slevin1
I just got one of those in along with one of these to power it.
[link=http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=4935]Click me![/link]
BIG motor.... the picture is deceptive.
On their Forums one member did a wonderful job checking out these EDF's and the motors.
See: [link=http://myhobbycity.com/showthread.php?t=351]EDF Thread.[/link]
He liked the motors, but the 4" EDF needs some work ( e.g. the motor retainer is FAR too weak! ).
He was getting about 2.8kg thrust out of that EDF which makes it viable as a way to power this plane and the StarFire EDF101.
Not bad for a $300.00 power system all told.
Old 02-11-2009, 05:24 PM
TOPCELLULAR
Can somebody help me with the Servos for that plane?
I like the Futaba but I have no idea wich model can fit perfectly.
Old 02-11-2009, 05:34 PM
opjose
opjose's Avatar
Standard Sized servos will fit fine.
Old 02-12-2009, 08:35 AM
flyboytha1
My Feedback: (30)
To Answer Some Qestion I'm Almost Done With The Eagle 100 Using Himaxx 96''s Fans And Motors Here's All My Build Videos Should Have (2) 6 Cells On Friday.
http://www.youtube.com/watch?v=4Uf7Hx2piNA Video #1
http://www.youtube.com/watch?v=sYQUxSJ6ezU Video #2
http://www.youtube.com/watch?v=KNyeprDzvNE Video #3
http://www.youtube.com/watch?v=Hy4MJEK3I6U Video #4 With Taxi Test
http://www.maxxprod.com/mpi/mpi-267_files/EPF96.pdf Site For EDF Fans & Motors
The Jet Came Out To 15lbs. With Retracts And (2) 5 Cell Thunder Power Lipo's For The Taxi Test. I Will Run (2) 6 Cells On The Maiden Flight. The 96 Fans Dropped Right In, Anything Bigger Will Require Some Work On The Nuculle's, Look For The Maiden Flight Here Soon.
ID:	1133580   Click image for larger version
ID:	1133581   Click image for larger version
Old 02-12-2009, 11:18 AM
TOPCELLULAR
Nice Job man!!!
What model of servos and retract are you installed in that plane?
Regards
Old 02-12-2009, 11:24 AM
flyboytha1
My Feedback: (30)
Hitec HS475HB Servo's & Robart 710RS Retracts
Old 02-12-2009, 11:46 AM
TOPCELLULAR
Thank you!!! Hope to see that plane flying soon.
Regards
Old 02-13-2009, 11:39 AM
flyboytha1
My Feedback: (30)
Here Are The Readings I'm Get On (1) Motor On (1) 6 Cell 3850 ThunderPower Lipo
Old 02-13-2009, 01:19 PM
opjose
opjose's Avatar
Excellent!
I saw that the PDF of the Fan was a bit out of line with what the MPI web page shows for the configuration... and that the PDF file was actually fairly pessimistic on the power estimates.
Your watt meter readins bear this out.
It looks like you'll have ample power and that your plane will scream!
Heh, do you have a turbine waiver?
Old 02-26-2009, 10:14 AM
flyboytha1
My Feedback: (30)
Here's The Maiden Flight Guys
http://www.youtube.com/watch?v=aEDGUKtt04Q
ID:	1145229   Click image for larger version
ID:	1145230   Click image for larger version
Old 02-26-2009, 11:50 AM
opjose
opjose's Avatar
Nice Work!
I also saw your Jet Trainer video too.
Old 03-17-2009, 10:47 AM
kihei11
My Feedback: (13)
WoW Thanks for the video and build info Hope to look up your flying club when I come to the bay area in June.
Again thanks, appreciate your efforts and expertise
Aloha Randy
P.S. If you're ever in Maui Give me a call, I got all the beach and ocean stuff you need
Old 03-19-2009, 08:44 AM
flyboytha1
My Feedback: (30)
Thanks My Man
Old 03-19-2009, 07:16 PM
slevin1
My Feedback: (23)
Flyboytha1,
Here is the newest jet from Nitroplanes. Have you purchased it yet?
http://www.nitroplanes.com/newuairfonad.html
http://site.nitroplanes.com/newplanes0309/grumman1.jpg
Saul
Old 04-03-2009, 05:47 AM
flyboytha1
My Feedback: (30)
The Reno Nevda Executive Eagle 100 Flight In My Tuxedo
Video Link Below
http://www.youtube.com/watch?v=hQPHnGB_odE
ID:	1171623   Click image for larger version
ID:	1171624   Click image for larger version
Old 06-11-2009, 11:09 AM
runblackbear
Anyone know any other places to purchase this plane besides Nitro Planes?
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
