CMP Giles Alternate CG check
IL
The CMP Giles 202 instruction manual shows to measure 165mm perpendicular to the fuse centerline and then 85mm/95mm back from the LE to get the balance points on the wing either side of the fuse. If i draw a straight line across the bottom of the fuse connecting those two points can I balance the plane on the flat bottom of the fuse to determine cg? If I'm balancing on the same cog line that is perpendicular to the fuse does it matter weather i'm out on the wing or at the flat of the fuse? I don't have a fancy balancer to support the plane at the wing. Also, is the plane right side up or upside down when balancing the cog?
RE: CMP Giles Alternate CG check
Upside down and I would ask someone at the place you fly if the have a CG machine it is well worth it to do it right. Good lock and enjoy.
ORIGINAL: hueyman
Remember the C.G. is where it is, so to speak.
You are trying to adjust the mass of the plane so that it has no particular preference to pointing the nose down or tail down, when suspended at that point.
Some people misake this with trying to achieve a perfectly level plane, when suspended at that point.
Often this is not possible, as veritical CG and lateral C.G. is not taken into account.
Normally low wing planes are checked upside down, while mid and high wing planes right side up, but really it's up to you.
You can do it either way.
Don't get too focused on trying to get the plane to remain level. You merely want no tendancy to always drop the nose or tail in particular.
ORIGINAL: hueyman
Re: Upside
The manual is specifiying right side up.
You CAN balance it upside down, but you will have an easier time doing so with a "fancy balancer" as the angle of the wings comes into play.
