CMP Kunlun Fuselage
RE: CMP Kunlun Fuselage
I have a Kunlun sailplane I just finished but the CG seems grossly wrong. In order to meet the recommended CG I would have to add 12+ oz of lead with the 8.23oz battery. Tell me that is incorrect. I built the Omie adding no weight at all. I was expecting nearly the same with this Kunlun
Most sailplanes are designed around heavier NiCD battery packs and heavy motors, so if you are putting in a LiPo pack it is not unusual to find that you have to add a lot of weight to the nose to offset the long tail.
If possible make the additional weight "usable" weight, by using a larger heavier pack, and moving things as far foward as possible.
Also remember that weight added to the nose ( e.g. a heavier spinner ) has a larger lever moment, requiring less overall weight to move the C.G. forward.
