P-51
P-51
I just got my P-51 and had a question on the prop install. There are 2 tapered collars on the motor and I assume 1 goes on first with the taper towards the prop plate, then the prop plate, the 2 collar with taper towards the nut. Just want to be sure as its not shown in the instructions. Also how tight on the nut?
RE: P-51
Not trying to belittle rcuniverse, but you will get more help here..
http://www.rcgroups.com/forums/showthread.php?t=1092043
