After Crash problemAilerons/Throttle controls reversed
I just flew my EDF F5 and had a crash. I put the plane back together and almost everything works right except the Aileron and throttle controls are reversed meaning the throttle lever moves the ailerons and the ailerons work the throttle. It has the Airfield N-4 2.4 ghz radio system.
Any one else have this problem and solve it?
RE: After Crash problemAilerons/Throttle controls reversed
Since the TX was not damaged, the most likely culprit is reversed connectors.. as suggested.
Reversing them should have had SOME effect, which tends to point to things not being hooked up properly.
Try unplugging one of the connectors and move the other into the two slots. Turn on the plane and check the affected channel.
