Hawk Sky motor cut out when increasing throttle
I recently bought a Hawk Sky. When I took it out to fly it, the motor could just stop if I increase the throttle too quickly and if I go past the half way point. Does anyone know why it does this? How do Ifix it? Batteries for the plane and transmitter are fully charged.
Transmitter has switches AIL and ELE in NOR, THR and RUD in REV. Trims are all in the middle.= Here's my steps in powering everything on: - Turn on transmitter - Connect the battery to the plane - Heard a beep, follow by 5 single beeps a few seconds later - Rudder, Elevator, Aileron all working fine - When increasing the throttle, motor would spin if I keep it at the bottom, but as soon as it goes max or increase too quickly, it would just stop. Thanks for any help you can give |
RE: Hawk Sky motor cut out when increasing throttle
Did you change your prop? Maybe its too big...
Or try reprogramming your ESC maybe it is set for hard start..it should probobly start with a soft start. Anyway ask your friends in the field how to program your ESC. Hope this helps<input type="hidden" id="gwProxy" /><!Session data><input type="hidden" onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" id="jsProxy" /><div id="refHTML"></div><input type="hidden" id="gwProxy"><!Session data></input><input type="hidden" id="jsProxy" onclick="if(typeof(jsCall)=='function'){jsCall();} else{setTimeout('jsCall()',500);}" /><div id="refHTML"></div> |
Try another ESC, the problem will go away when you change that out.
| All times are GMT -8. The time now is 12:36 AM. |
