Nitroplanes batterys???
Hey guys, I just got my F15 in the mail from nitroplanes and I ordered an extra battery as well. It is a 2200mah sky lipo battery and for whatever reason the connector wont plug into the esc, seems like the one on the battery is smaller than the one on the esc. Anyone else have this problem??
RE: Nitroplanes batterys???
Which F15 did you purchase?
There are F15's from at least two vendors sold on NP's site. It is possible that the connectors differ in size by as small as .5 mm. Do the tips of the plugs insert into each other? Also try inserting just one side at a time. You can hook up both of the negatives or both of the positives. I do this with new packs to break in the connectors. |
I got the Airfield F15. The battery in question is the sky lipo 2200 mah pack. I cant plug either the positive or negative side in, both are slightly too small. The connectors do seem off by a very small amount. Ill probably just get them replaced with deans at my local hobby shop or just do it myself.
