Spitfire 25
I got one...it's splendid. Surprising in many ways. All built up balsa, all incredibly nicely done, incredibly light. Looks good, too, much more scale than most of the spits out there. Took only three hours to make her all ready, except I am waiting for a motor from Balsa Products. Comes with two complete mounts, one for glow, one for electric. I tested an OS 40 four stroke for fit, will go in with no problem, but I am going electric.
I'm tough and picky, and an old school balsa basher, but I really like what I have gotten in this box, I'm very impressed. And, surprisingly enough, the instructions were just fine, plenty adequate to get the plane together. |
RE: Spitfire 25
a review is being done by curtis mattikow on this model and it will be released very soon...he also said the same positive things :D... not sure which magazine but he writes for RC Jet International, Quiet and Electric Flight, and others...
RE: Spitfire 25
Motor arrived today from BP, should fit it and test fly it tomorrow...
RE: Spitfire 25
I have to agree, this is one of the best ARFs I've ever seen. I just got mine in this week, and it is impressive. First of all, the covering is amazing. It's tight and the material is thick. There is not one wrinkle in sight. All the graphics is printed directly onto the covering and it looks great. If this wasn't a flying bird, it could pass for a stand alone plastic display model. I mean, it's that good!!! Second, the plane is light. I haven't finished building it yet, but I'm estimating the final weight to be about 2.5 lbs with my electric motor and 4000mh battery setup. Also, the plane looks to be a really easy build. I spent a couple of hours on it already, and it's almost done. The engineering and design of this plane was well thought out. And two motor mounts come with the plane. If there are any gripes about the plane, I would have to list two. If you ever crash and damage the covering, you're going to have a hell of a time fixing it up and making it look back to stock. I don't think anyone can repaint the graphics back to make it look perfect. Second, the electric motor mount doesn't allow you to install a brushless outrunner in front of the mount. If you try to do it, the motor sticks out too much. I'm installing an AXI and it appears I can't use the motor mount that comes with the plane if I want to install it in reverse. Other than that, this plane looks awesome. The instructions that come with it are clear and easy to follow. In terms of looks and build, this is the best I've seen from any manufacturer. Can't comment on the flying yet as I still have to maiden it. Plan on doing that next week.
RE: Spitfire 25
I maidened my plane today. But before I get into that, a few things about finishing off the plane. The ARF doesn't come with any holes to vent out the hot air from the motor. You will have to drill holes somewhere to do this. I drilled two in the front cowl and and six in the rear of the bottom of the fuse. If you don't do it, I don't know how and where you're going to vent out that hot air over a 10 minute flight. Second, the battery hatch is attached with magnets. This is awesome. It is so secure and snug, I just had to mention it. Okay, on with the flight summary.
The Spitfire is set up with the following: AXI 2814/12 4000mh lipo, 11.1 v 45 amp Great Planes esc Total weight of plane is about 2.8 lbs. 9x6 Master airscrew prop This plane takes off quick. You won't need a lot of runway. Be careful not to add to much elevator because the plane will go straight up really easy. At full throttle, the plane has a good amount of speed. It doesn't appear to be as fast as the Great Planes Combat Corsair, but you won't be disappointed. This thing will rip through the sky and you only need about 1/2 to 2/3 throttle to accomplish it. Giving it full throttle will only give it a little more speed for some reason. I don't know why this is the case. Maybe changing out the prop will give it more speed, but I'm pretty happy with how fast it goes right now. On turns, this thing rips. It doesn't turn like my Combat Corsair or Great Planes electric Sportster. When you give left or right aileron, you have to give up elevator to make it turn. The plane doesn't just turn with aileron only input. Hence, a beginner will have problems with this. Also, just a little elevator will make this thing roll left or right. The funny thing is, a full barrel roll takes forever seeing how twitchy it is with a little input. I guess that's just the way warbirds are. Loops with the elevator are no problem. You can have the tightest loops with the setup I have. Just be careful though. While doing two loops, I accidentally gave it some aileron input and it turned on me during the loop. Good thing I was high enough to recover orientation. The plane also has an excellent stall speed. You can bring it down to less than 1/4 throttle and it will still fly quite fast. At zero throttle, the plane will glide in and you could land it if you're good enough. Floats like a butterfly, stings like a bee. My Combat Corsair couldn't do this at all. It would just nose dive if there wasn't enough throttle. One problem I did notice is that when you add throttle, the nose will tend to lift, and a lot. I think there isn't enough down thrust built into the firewall. I'm probably going to add 1/2 ounce of weight to the nose and shim the motor mount to give it a little more down thrust to correct this problem. Against the wind, I kept having to input down elevator to keep it flying level. Nothing bad, but I should be corrected. Other than that, it was a great first flight. I had to bring it in because it was drizzling out and my radio was getting all wet. Any intermediate flyer will love this plane. For $100, it's the fast building ARF ever and the covering is top notch. |
