RCU Forums
-   NitroModels Support (https://www.rcuniverse.com/forum/nitromodels-support-456/)
-   -   voyager CG (https://www.rcuniverse.com/forum/nitromodels-support-456/5663209-voyager-cg.html)
msarid 04-04-2007 07:14 AM
voyager CG
HI all
Did somebody know what is the correct Electric voyager CG and what is the recomended brushless motor?
Moti
Rube Goldberg 04-04-2007 01:29 PM
RE: voyager CG
I don't have the electric version of the Long-EZ that they call the "Voyager", but I do have the yellow version of the glow powered model. Here is a link to an online CG calculator that I used to verify the given CG of the one I have, which turned out to be within just a few millimeters of the same spot.
http://adamone.rchomepage.com/cg_canard.htm
I'd suggest you keep searching for the factory specification and verify it like I did with the calculator. Good Luck!
Rube
msarid 04-12-2007 07:36 AM
RE: voyager CG
Hi all
If CG is like apear in nitro web site I have to add 170 grames to the nose.I also install 3s 2500 lipo in the airplane nose
IS THIS IS NORMAL? did somebody have this problem?
Please advice
Moti
