Control throws for Ultimate 40 Bipe
Just finished my Ultimate 40 Bipe. What are you guys out there using for high and low rates.
RE: Control throws for Ultimate 40 Bipe
IMHO: It's hard to get TOO MUCH throw out of the ailerons on this plane.
Maximize the throws and then set your TX to use about 60% of this for the low rates with about 20-25% expo and full travel for the high rates at 50% expo. For the elevator use the recommended setting for the low rates at about 35% expo, and about 1/2" or so MORE for the high rates with 50% expo. For the rudder again use the recommended setting for low rates, but at 15% expo and ALMOST as much as you can get for high rates at 50% expo. Fly the plane with low rates and once you have it trimmed out ( BE PREPARED! ), and HIGH in the air, try out the high rates to determine if you want less. |
| All times are GMT -8. The time now is 10:28 AM. |
