Yak 54 120 - 69"
I received one of your Yak 54 120 - 69" ARF, order # 369483, and the rudder for it is cracked where the control horns are to be mounted. I am in need of a replacement with the hardware.
I have just started putting it together when I found this problem as I was gluing in the horns. My email address is ; [email protected]. Thank you |
RE: Yak 54 120 - 69
EZer,
Any chance to post some photos for your yak assembly If knowing some links might help for the same , this will be appreciated Thank you |
