Nitro model extra 300s manual
I have completed a Nitro Extra 300S plane. The manual that I received with the plane was for a 40 size plane (1440mm wing span) but the plane I received is a 60 size aircraft (Approximately 1610mm wing span). My only problem is I do not know what the recommended
CG is for the larger plane - can you please forward to me at what point I should set CG? Sonnytex |
RE: Nitro model extra 300s manual
I'll post this later tonight...
Great flying plane... I'm on my second. I managed to fly my first one through a tree, doing outside Cuban eights. Even with no rudder, smashed wing and part of a tail it kept flying... and I was able to get it down with all the pieces hanging off of it. It can actually be easily repaired if I ever find the time, but I missed it so much I had to get another... |
I have not, and now, never will buy anything from these guys. I feel so sorry for the RCU members who post all these negative experiences with these people. Price isn't everything.
Bill |
Did that answer the original poster's question?
what's your order number? I can provide you CG for that.
John Nitro Planes ORIGINAL: sonnytex I have completed a Nitro Extra 300S plane. The manual that I received with the plane was for a 40 size plane (1440mm wing span) but the plane I received is a 60 size aircraft (Approximately 1610mm wing span). My only problem is I do not know what the recommended CG is for the larger plane - can you please forward to me at what point I should set CG? Sonnytex |
| All times are GMT -8. The time now is 12:33 PM. |
