70mm NitroPlanes F4 Phantom rates
Can someone post the standard low and high rates for the 70MM F4 Phantom? Thanks
Keith |
RE: 70mm NitroPlanes F4 Phantom rates
It depends upon what you want and the TX you are using.
I fly these planes with a computer controlled transmitter, so I set up a good bit of expo ( about 50% ) on both high and low rates. That lets me maximize my high rate throws. If you are using a non-computer controlled TX then you want to keep the movement somewhat low, no more than 10-15mm, and even that may seem twitchy in any sort of breeze or light wind if you are not used to flying without Expo. |
It's A Great Flyer Very Stable. I Even Painted Mine's :)
Video Link Below: http://www.youtube.com/watch?v=45OoXVwpbZ4 |
I am using a computer radio. So do you think 10mm low and 15mm hi for both ELE and AIL is a good starting point?
ORIGINAL: kcollier I am using a computer radio. So do you think 10mm low and 15mm hi for both ELE and AIL is a good starting point? |
