O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS FS 200 S, Oil in the crankcase
Old 02-03-2014, 12:47 AM
kartika
Default OS FS 200 S, Oil in the crankcase
I have OS FS 200 S, flew for fun fly about 20 liters of 80/20 methanol /oil with 0% nitro with no any problem. easily started on with a 17x10 propeller @ 7800 rpm.
currently cleared an engine, in the crankcase there are plenty of clean oil (almost 1/4 part of crankcase)
This is normal for OS FS200S ? or any problem with my engine?
Note, before the disassembled engine runs fine.
Best regards
Old 02-03-2014, 07:33 AM
Bax
It is normal to find oil in the crankcase of any model engine. There's always some that doesn't go out the vent.
Old 02-04-2014, 01:11 AM
kartika
Hi Bax..
Thanks for your fast respond and your explanation
I was surprised to see a lot of oil in the crankcase (such as 4 stroke gasoline engines in general).
so the engine will last longer because it submerged in oil so good lubricating and better anti-corrosion as I saw in my engine
After the engine is reassembled, and the engine running perfectly again without any problems.
Best regards
Old 02-04-2014, 07:27 AM
Bax
The oil residue is actually not good for storage. It contains combustion products, which are somewhat corrosive. When done flying for the day, you want to flood the lower-end of the engine with a good-quality after-run product to prevent corrosion.
Old 02-05-2014, 12:39 AM
kartika
Oo..I have thought the opposite direction , but I really love my FS 200 S.
Thanks a lot Bax..
Best regards.
