O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS55HZ Hyper Break In
Old 04-16-2014, 06:03 AM
daskip87
Default OS55HZ Hyper Break In
I just purchased a new OS55HZ Hyper engine with a new Power Boost pipe for my 600N and had a break in question. I have been running 15% Cool Power fuel in my OS50 but am planning to run 30% in the new engine. I have a gallon of the 15% left and was wondering if I could use that for break in then switch to the 30%?
Old 04-16-2014, 06:57 AM
Bax
You can, but you'll still need quite a bit of running on the 30% to get the engine to "come in". It's best to break it in with the fuel you'll be using, especially since the fuels are radically different. 30% heli fuel is a lot "hotter", and usually has a different oil package than a 15% fuel. Needle settings will be very different between the two fuels, too.
Old 04-16-2014, 06:59 AM
daskip87
Ok. I guess I will just start with the 30% then. Thanks for the reply.
