O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
converting 91 FS II pumped to non pumped carb
Old 09-16-2014, 07:56 AM
raptureboy
raptureboy's Avatar
Default converting 91 FS II pumped to non pumped carb
Can the 91 pumped be converted to run on a non pumped carb? If so, what carb would work?
Old 09-17-2014, 07:26 AM
raptureboy
raptureboy's Avatar
Hello, anybody home?
Old 09-19-2014, 08:56 AM
Bax
You'll need a new rear cover, intake manifold, and carburetor.
Old 10-10-2014, 07:35 AM
GRandolph
GRandolph's Avatar
I see that I am not the only one interested in doing this. I will buy the intake manifold and 60P carb. I will simply plug the vent line on the crank case cover so I won't have to replace it also. Why am I spending all this money to convert a pumped engine to non-pumped? Because the pump/regulator does not last! I have had mine repaired twice now, and this last repair still did not fix it. I have a perfectly running engine, it just can't get the fuel.
