Go Back  RCU Forums > Glow Engines, Gas Engines, Fuel & Mfg Support Forums > Engine Manufacturers Direct Support Forum > O.S. Engines Support
Reload this Page >
Would camshaft timing one tooth out cause a F/S engine to run hot?
O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
Old 11-26-2014, 12:10 AM
Lynton
Default Would camshaft timing one tooth out cause a F/S engine to run hot?
I have an OS 120 Surpass which runs seems to be running excessively hot. If the camshaft timing is out by one tooth could this be the cause?
Old 12-01-2014, 09:16 AM
Bax
Not likely, since getting the cam off by one tooth will make it run badly. If the engine's getting too hot, then it's either using a fuel with insufficient oil, not getting good cooling, running too lean, or has too much of a prop and is lugging.
