O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 91 RZ compression
Old 05-15-2015, 09:07 PM
f3d
f3d's Avatar
Default OS 91 RZ compression
Hallo Bax,
I have bought 3 OS 91 RZ rear exhaust engines and run them in fast RC1 classic pattern ships.
2 of them have normal/ low feeling compression when you turn over the top. 1 has a very high compression when you turn over the top.
Do you have a explanation for this ?
Regards Michael
Old 05-18-2015, 06:19 AM
Bax
A higher-than-normal compression feel can be caused by a ring seal that's tighter than normal, tolerances all in the positive direction that create a bit more of a compression ratio.
You can get a high-compression "feel" if the connecting rod is bent. Then the engine will be difficult to turn over as the piston rises.
