O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
O.S. 1.20 AX rebuild
Old 07-28-2015, 05:35 PM
dbacque
Default O.S. 1.20 AX rebuild
I have noticed my 1.20 AX is feeling weak in verticals. Compression also feels low. I figured it was time for a ring and cylinder sleeve.
When I disassembled the engine, I found the ring was broken and the piston heavily scored. Okay, I need to order a new piston too.
I thought this piston had an arrow engraved into the top but it's all invisible at this point, the engine has LOTS of time on it. When I get the new piston, what is the correct orientation?
This engine has been magnificent. It's a powerhouse and I've gotten more miles than anybody has any reason to expect from an engine. I'd just like to make sure that I rebuild it correctly so I can do it again.
Dave
Old 07-29-2015, 06:52 AM
Bax
There is a pin in the piston's ring groove that locates the ring gap. You want the ring gap to be on a web. That's usually between the aft intake port and the port directly opposite the exhaust. Once you examine the piston, it becomes obvious.
Old 07-29-2015, 02:16 PM
dbacque
Exactly what I was looking for. Thanks Bax!
Old 05-30-2020, 04:18 PM
acejinx
Default Great!
I needed that answer also! Thanks. Such a great engine.
