O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
os surpass fs 120
Old 01-14-2016, 02:59 AM
rhk
Default os surpass fs 120
My engine chewed through the rear bearings. Replaced both the front and rear beariings. Reset the valves, and timing, however the engine does not fire or draw fuel from the tank. The carb is clean and there is unobstructed flow from the fuel tank. Any suggestions would be welcome.
Old 01-14-2016, 06:56 AM
Bax
If your engine is set up correctly, we'd not know why it would not draw fuel. You may need to check the valve timing and possibly the compression.
