trouble with replacing low speed needle
My Feedback: (28)
MO
Got OS 46 AX and lost low speed carb idle needle. got new one, part 24681610 and cannot get it to screw in the carb cylinder. any ideas? do I need to take off something first then put the low speed "metering needle" in? thanks. [email protected]
ON, CANADA
Very strange that you would lose the needle unless it was taken out and then lost.
If you check the instruction manual here: http://manuals.hobbico.com/osm/46ax-manual.pdf you will see that there is a rubber "o"ring on the needle. This provides sufficient friction for it to stay set and not unscrew.
So how did it come out?
It should simply unscrew, although not on its own and not without your help and the replacement would be screwed in. If there is some obstruction, such as broken off part from the old needle in the carb barrel, then the new one will not screw in properly.
If the engine is an OS 46AX II, the carb and needle arrangement are different.
You need to check the needle. It must have the small o-ring. Otherwise, it won't stay in. If it won't screw into the housing, then there may be a problem with the threads in the housing, which is also the nut that retains the carburetor arm, or the needle is damaged. You'll have to check it all over very carefully.
