O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
Info on FS120S II
Old 11-01-2003, 04:31 PM
crashed2's Avatar
Default Info on FS120S II
I just got a hold of a used FS120SII. I heard something about the pumps on these engines put out excessive fuel pressure to the carb. Is this correct? Is there a simple fix for this?
Also, are there any other known problems with this engine that I sould be aware of?
What is your take on these engines?
Thanks for your EXPERTISE!
Oh Yeah.
This is my first 4 stroke, and I read a post about 4 stroke fuel, and I am kind of confused. I heard that I should run at least an 18% oil content. In the post, some where saying 20%, and as low as 16%, (you can see why I'm confused). I run Wildcat 15% nitro, w/16% oil content in my 2 strokes, would that be ok to run in the 120, and if not, could you give me some giudlines to follow when selecting fuel for this 4 stroke?
Also, I am at 7000ft Elev. if that makes a difference.
Thanks again!
Old 11-03-2003, 10:27 AM
Bax
Default RE: Info on FS120S II
For setting your engine, please see the O.S. web site FAQ:
http://www.osengines.com/faq/faq-pumped.html
An fuel with at least a 16% oil content will be OK. A fuel with a higher oil content won't hurt the engine one bit.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
