O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 46FX - starts backwards
Old 08-19-2002, 01:16 AM
Default OS 46FX - starts backwards
I have an OS46FX running with APC 12.25" x 3.75" prop and fuel containing 5%Nitro, 13%synthetic and 2%castor. The plug is O.S.#8
4 out of 5 times this engine starts the wrong way. It does not matter which way its flicked, it still starts backwards most of the time.
My questions are:
AA Is it bad for the engine.
BB Is there something wrong with the combo I am using.
The engine is mounted on a light airframe, the "Limbo Dancer" and performs flawlessly, once it gets going. Its very easy starting, except for the fact that it wants to start backwards.
thanks and best regards
Old 08-19-2002, 01:57 AM
Default Me too
I also have an Os 46 fx and have the same problem with it starting up backwards often. Otherwise runs great. Using the same fuel as in the TT 46 and GMS 47's. Only the OS does it. Any Ideas for us?
Old 08-19-2002, 02:21 AM
My Feedback: (10)
C_Watkins's Avatar
Default I have an OS 46 SF the same way...
It doesn't hurt anything that I know of, and usually a blip of throttle turns it around.
Old-school trick... while it's spinning backwards at idle, *carefully* give a gentle
squeeze of the hub/spinner between thumb and forefinger. It will kick and run forward.
Ok... maybe that's not good advice for some of ya.
Kids, or lawsuit happy people... don't try that. It could kill you, or even worse
Tip to keep it from happening... always?
Always start it with the starter, instead of hand-propping.
I know... they start so well, first flip always, that I hate to do it, too.
Old 08-19-2002, 02:27 AM
My Feedback: (12)
I have seen the same thing from my OS engines when I hand flip them most of the time I use a starter. A starter cures the problem.
Old 08-19-2002, 03:13 PM
Bax
Krazy,
Usually, if a model 2-stroke engine tends to run backwards when hand-flipped, it's been a bit over-primed. You might also have a plug that's a bit too "hot" and is setting off the fuel/air mixture early. We'd suggest an OS #8 or #A3 plug, if you're not already using one.
We hope you find this information helpful. Should you have any further questions or concerns, please do not hesitate to contact us at this email address. (Please be sure to copy all previous emails into any future questions.)
DID YOU KNOW that our web pages now all contain FAQs? (Frequently asked questions) Please drop by and take a look! We hope you'll find the information helpful and valuable to you.
Sincerely,
Bill Baxter, Manager
Hobby Services
1610 Interstate Dr.
Champaign, IL 61822
USA
Phone: 217 398-0007
Fax: 217 398-7721
Email: [email protected]
Web: http://www.bestrc.com
Old 08-19-2002, 05:09 PM
Usually a flooded or overprimed engine will run backwards when flip started.
Old 01-18-2003, 06:21 AM
Hey Krazyflyer, dont your toilets flush backwards down there also. Ha Ha. lol
Old 02-24-2003, 01:14 AM
Default hand starter
the only advice i can give you is to start it with a hand starter (electric thing).
almost guarantee starts right way every time!
So get ye self a stater!
Old 03-06-2003, 07:48 PM
Get a starter from tower hobbies 19.00 for a WORKING STARTER
Old 03-08-2003, 03:01 AM
both my engines love to fire up and run backwards, in fact my .40fx engine fired up backwards with my starter and broke the shaft that connects the spinner cup to the motor. Anyways, my trick to get the engine running the right way is to either open up the throttle all the way, or put your finger half way over the carb and open the throttle. Nowyou'd think this would choke the engine and run it even richer but it works, be careful though to not cover the entire carb because you can create a hydraulic lock in the engine, not only will this damage the engine, it will really hurt your finger.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
