O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS 120 Surpass II
Old 03-05-2005, 07:47 PM
My Feedback: (77)
Bill Rademacher's Avatar
Default OS 120 Surpass II
Hi,
I am trying to determine if I have bought a paperweight with an airplane purchased at a swap meet.....
I have an OS surpass II Pumped. It has the silver pump on the backplate with NO brass screw. It has the carb intake velocity stack.
I believe it has sat for a while. We are getting inconsistent idles, high ends. etc. I read the FAQ, and all the other posts about rejuvenating the diaphram, so I'll run several 16 oz tanks through it and see if that helps.
My questions are:
How much fuel should pump out of the pump if I hit it with a starter, and leave the hose off. Should I see a good solid stream?
Can I take the carb mounted diaphram apart and replace any of the parts there?
If I replace the c13 carb, does that contain the diaphram regulator?
I have emailed support for the manual.
thanks
Bill
Old 03-07-2005, 11:14 AM
Bax
Default RE: OS 120 Surpass II
When you turn the engine with an electric starter, you should see a good stream of fuel come out of the pump.
The diaphragm in the carb is not available as a separate item, but does come with a C-13 carb body.
Old 03-07-2005, 01:51 PM
My Feedback: (77)
An entire carb? I think that is over 100 bucks. Ouch.
thanks
Bill
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
