O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
os 61 sf
Old 03-08-2005, 11:56 AM
Default os 61 sf
i have a 61sf and im going to put it on a older pattern ship . i would like to know if there is any hop ups for this engine as every one told me it might not have enuff power thanks
Old 03-08-2005, 12:25 PM
Bax
Default RE: os 61 sf
The O.S. Max .61 SF is a fine engine in its own right. The main problem people had was putting too much propeller on it and running it too slowly. It should be propped to run in the mid- to high-11,000's. We normally ran a 12 x 7 or 12 x 8 APC prop.
The only thing we can add is that a properly-tuned exhaust system will contribute to the output of the engine.
Old 03-09-2005, 08:07 AM
hi thanks for the advice. can you suggest a good tuned pipe fpr this engine and does os still sell a header for this engine thanks
Old 03-09-2005, 12:43 PM
Bax
The O.S. header and pipe are:
OSMG2710 72101230 EXHAUST MANIFOLD 61SF $44.99
OSMG2943 72101120 TUNED PIPE .61 HANNO $164.99
While the pipe was specifically for the Hanno, properly-tuned it will work with the non-Hanno engines.
Both are available and can be ordered through any hobby retailer who sells O.S. Max engines and accessories.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
