O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
My OS 10 wont run right
Old 09-29-2002, 02:43 AM
Default My OS 10 wont run right
I bought a used OS 10 FP from a guy at work to put on my glider. He says it was hardly used and it looks it. I made sure the carb was clean before I put it on the plane. Now my problem it runs fine, good idle,also good in the middle but when I go to wide open the RPM's start dropping. I noticed that if I richen it up it gets a little better. Does this mean that it is leaning out on top?
Also I took the middle section out of the muffler out is that OK? I was hoping it would help the problem but it didn't. I was also hoping to get a few more RPM's if I could ever get it to run right. Oh and it has a new plug to, OS #8 I think.
Thanks Dave
Old 10-02-2002, 07:07 PM
Did I post my question in the wrong place? Did I not give enough info? Is it a stupid question? Why am I not getting a response.
Old 10-07-2002, 03:55 AM
My Feedback: (12)
i have posted to i dont thing they like the older engines :cry:
Oh and you need the flip the prop in the LEFT direction so it will start
sorry couldnt help my self hehehe
Old 10-08-2002, 07:28 PM
Bax
baddog,
Sorry your question got missed.
Your post doesn't mention what propeller size you're trying to run. The .10-size engine should be running a 7x5 or 6 propeller. If you're running one much bigger, then you're trying to use too much prop, and this could well be a source of your difficulty.
The O.S. Max .10 FP engine is a bushing-type engine, and will benefit from a fuel that contains castor oil. Nitro can be 15%-20% with no problems.
Make sure your glow plug is good. Just because it glows when the battery is applied doesn't mean it's good. It could still be contaminated enough to not work properly.
If the compression is good, the plug is good, and the fuel is good, the engine will fire and run.
We hope you find this information helpful. Should you have any further questions or concerns, please do not hesitate to contact us at this email address. (Please be sure to copy all previous emails into any future questions.)
DID YOU KNOW that our web pages now all contain FAQs? (Frequently asked questions) Please drop by and take a look! We hope you'll find the information helpful and valuable to you.
Sincerely,
Bill Baxter, Manager
Hobby Services
1610 Interstate Dr.
Champaign, IL 61822
USA
Phone: 217 398-0007
Fax: 217 398-7721
Email: [email protected]
Web: http://www.bestrc.com
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
