bx1 108
NC
RE: bx1 108
I have a used bx1(108), what is the fitting on the back of the crankcase used for? The engine continues to run when I close the carb while running it on a test stand, if I pinch the fuel line attached to the fitting on the crankcase when I close the carb it helps shut down the engine. How much Nitro and prop size recommended? Thanks!
RE: bx1 108
The stock O.S. Max 1.08 FSR had no fitting on the rear cover. That would have been added by somebody at a later date to provide crankcase pressure to operate a pump or to pressurize the tank. It should be blocked all the time you're running the engine. It will tend to be too lean, otherwise.
RE: bx1 108
Also do you use muffler pressure to the tank if you are going to run the pump?
Thanks for your expertise Bill.
RE: bx1 108
ORIGINAL: ricomari
