O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
what glow plug/fuel combo for v-spec
Old 06-03-2007, 02:01 AM
Default what glow plug/fuel combo for v-spec
What glow plug (medium, hot, ultra hot, etc.) would you recommend for the .21 v-spec and what fuel (nitro %) would you recommend for that plug. Also will I need to use the extra head shim that comes with the engine. Thanks.
Old 06-04-2007, 10:14 AM
Bax
Default RE: what glow plug/fuel combo for v-spec
Plug depends upon the fuel you use. If the engine's detonating, then you can go to a colder plug, or add a cylinder head gasket to lower the compression. We can't give you an "either-or". It all depends upon how you've chosen to run the engine.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
