O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
FS-120 Surpass Version 1 fuel line size
Old 07-14-2007, 11:39 PM
Default FS-120 Surpass Version 1 fuel line size
I have a FS-120 Surpass Version 1 that I am getting ready to finally use. I know it is Version 1, C-12 carb and pump with the brass screw. Which fuel line size is best," 3/32 or 1/8". Fuel line length is about 4 inches from tank to pump and tank is about 1 inch above pump.
Thats for:
Fuel tank to pump IN
Pump OUT to Needle valve
Pump RETURN to fuel tank.
Old 07-16-2007, 10:47 AM
Bax
Default RE: FS-120 Surpass Version 1 fuel line size
You can use "Medium" or "Standard" fuel tubing. That has the 3/32" I.D. Larger tubing is OK, but you'll likely have to use ties to hold it in place.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
