Best prop for OS 1.20 AX
TX
I will be using this engine on a Carl Goldberg Ultimate Biplane.
About the clearances: Airframe can handle 15"and 16" props. I think that 17"could also be manageable but dangerously close to earth.
I would like to know which prop could be the best for this combo, and also want to know if I should go with a wood option or an nylon-composite type.
I have seen a comment (At user reviews) where the user explains that almost all sizes of props will tach 9000 at full throtle. I wish to read more comments from users of this particular engine.
Thanks.
Thanks.
RE: Best prop for OS 1.20 AX
This is the O.S. Support Forum. We don't have an answer for you, because there is no "best" propeller. The best prop is the one that flies your airplane the best. You have to try several and see.
If you want other people to comment, please do so in the Glow Engines forum. This is not a discussion forum.
