O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
OS engine suggestion ...
Old 12-01-2009, 08:39 AM
Kostas1's Avatar
Default OS engine suggestion ...
Hello Bax!
I want your help so as to decide for the best engine !
I am putting together a Seagull Percival Mew Gull,
with the following specifications.
* Wingspan - 74ins (1.88m)
* Wing area - 797.2sq.ins (51.4sq.dm)
* Suits - 120 2-Stroke (120-160 4-Stroke)
* Factory covered with Profilm Cream (12)
* Length - 60.1ins (152.7)
* Approx flying weight - 10.1-11.0lb (4.6-5.0kg)
What OS engine should i use?
I prefer two strokes.
I have found some good deals here on RCU market ,
regarding 91FX , a 108FSR .
I prefer to buy a used one because of the lack of money.
I just don't know if the OS 91FX will be enough (sport flying/but what prop ?)
Anyway,
i hope i *read* from you soon,
Konstantinos
Old 12-01-2009, 10:01 AM
Bax
Default RE: OS engine suggestion ...
At that size and weight, the model will actually fly with anything from a .61 on up. After all, we used to fly 8-10 pound models on a .61 all the time. A .91 FX should be OK, as would a .95 AX or a 1.20 AX. If you go with a .91 FX, then a 13 x 8 prop, or a 14 x 6 prop, or that vicinity. Turn the engine at about 10,500-11,000 RPM and you'll do well.
Old 12-01-2009, 11:28 AM
Kostas1's Avatar
Bax you mean if i use a 91FX right?
You think that a 91FX will turn a 14x6 APC at 10k RPM ????
Old 12-02-2009, 10:16 AM
Bax
.91 FX, yes. I edited the original post.
Old 12-02-2009, 01:46 PM
Kostas1's Avatar
Hehe no problem.
Do you know what rpm usually someone gets from the APC 14x6 and 91FX ?
Old 12-09-2009, 10:07 AM
Bax
We're not sure about hte 14 x 8, but with the 15 x 8 APC, we'll get 8,500 RPM. However, if noise isn't a problem, you can use whatever propeller will allow the engine to turn as high as the high-11,000's and fly your model. You'll get "sparkling" performance running the engine in that regime. O.S. uses large propellers to keep sound as low as possible due to very strict noise standards in Japan.
Old 07-26-2010, 07:39 PM
AraTidwell's Avatar
Considering I have a Ultrathrust muffler on a 91fx and I'm getting 11,500rpm smoky with an APC 14x6 yes I think you will get 10k
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
