O.S. Engines Support Ask Bill Baxter your questions about O.S. Engines.
FS-91S No Pump, Needle Valve Setting
Old 09-06-2010, 07:08 PM
arobatto's Avatar
Default FS-91S No Pump, Needle Valve Setting
Greetings Mr. Baxter,
I have a 2000 FS-91S without a pump that needs to have the needle valve fully closed to run lean enough. In searching this forum I learned that it may be a worn needle valve seat, a worn needle valve or a combination of the two. May I ask what part/s would be needed to correct this problem? Also, may I trouble you for part numbers if available?
Best Regards,
Alex Robatto
Old 09-07-2010, 09:09 AM
Bax
Default RE: FS-91S No Pump, Needle Valve Setting
You'll likely need a new needle valve and carburetor body. The symptom indicates a worn needle seat in the carb body. The needle will have a polished ring on the pointy part, which indicates wear.
Old 09-07-2010, 09:25 AM
arobatto's Avatar
Thanks for your quick reply sir. Since I don't have the original manual, may I ask if if the following are the correct catalog numbers?
Needle: OSMG7062
Carb. Body: OSMG3578
Thanks again,
Alex Robatto
Old 09-10-2010, 12:18 PM
     Greetings,  I have an O.S.91-fs(nopump) Quest.? can someone tell me(approx.) How many turns out(counter-clockwise) after seating the needle, is recomended for starting ? thanks.
Old 09-13-2010, 09:14 AM
Bax
Arobatto: Those are the correct stock numbers.
Fullflaps: Start out with the needle at 2-1/2 turns out from closed. You'll have to lean the engine from there.
Old 09-13-2010, 11:21 PM
<u> Re: Needle setting </u>    Thanks Bax ~ I've just entered into Gas/glo- from <u>electrics</u>,  and needed a Jumping off point.(many Thanks again [8D]
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
